David Moskovic
Hello,
I have a megaflop hot water tank. On the wide, it has two grey plastic squares attached. On them is written "DISCONNECT FROM THE MAINS BEFORE REMOVING THIS COVER".
They have holes for two wires to be attached. The upper one, about 2/3 up the tank, is not onnected. The lower one, near the bottom, has one wire going to a plug socket, into one hole. It has another wire from the other hole, but I cant trace what happens to it. The plug socket is off.
The previous owner said it was an immersion heater. I used up the hot water and turned it on, but it did not heat any water.
The other thing I think it could be is an electric anode, in which case I should obviously switch it on. I attach a photo. Does anyone know if this is indeed an electric anode and if it should be turned on.
Very grateful for anyone who can help!
David
David
