Essential Plumbing Tools
View the thread, titled "Essential Plumbing Tools" which is posted in Plumbing Tools on UK Plumbers Forums.
Hey all,
First post here, am an avid DIY'er and I'm putting in my mother-in-law's bathroom this weekend, this will be the 3rd bathroom that I've put in, however, I always get by with the poor tools that I have.
In your experience what would you say are essential tools?
I'm also looking to buy some welding tools, what would you suggest?
As a DIY'er how much plumbing/bathrooms are you really going to be doing to justify buying more specialist hi end equipment? Might as well stick with push fit or tectite fittings and just use a pipe slice if you can't solder.
Bathroom essentials would be monobloc spanners/water pump pliers/ pipe slices/ fugi kit/ silicone grease/ basin wrench + box spanner (get both)
The rest of it would be basic tool set.
Then you move into specialist kit: tile cutters/ trowels/pipe benders/ sds drill for removing tiles/ 6ft spirit level/ multi tool for floor boards
Whatever tools are needed I always seem to have left them in the van😂
Nearly 20 years on and I'm still incapable of setting up with everything I need.
I'm great at running up and down stairs tho!
I guess your mother-in-law like bathroom changes? 🤔🤣 Joking aside, spend what you can afford for semi decent equipment. What I mean by that is don’t purchase all Silverline tools but you don’t need high end either. Stanley tools are usually decent enough imo, probably better with a Bahco wide adjustable though, Knipex grips can be had for some good prices or go Rothenberger.
Best answer
Reply to the thread, titled "Essential Plumbing Tools" which is posted in Plumbing Tools on Plumbers Forums.
baxter111,
jerrysimpson,
