Jul 5, 2022
Ireland
DIY or Homeowner
Hi all,
Hopefully this is in the right section. (Admin feel free to move if necessary).
I have a new build nearing completion. I went with a 7Kw split Ecodan system.
The house is extremely well insulated and air-tight.
If it wasnt for hot water for showers etc, we would expect the unit to be off 6 to 7 months of the year.
With the cost of electricity and PV solar having to come a ways further to break 20% efficiency, i’m holding out paying €15K on PV / Battery just yet as the only thing bringing down the ROI presently is the artificial hyper-inflation of energy production.
So…… what i was thinking of doing is having an evacuated tube array installed and combine this into the ecodan tank ?
My thought is this would prevent having an A2W unit running just for shower water.
Is this possible?
I would rather not have a complicated setup with 2 tanks etc, but if the tubes could heat the water and send into the reservoir tank of the Ecodan unit, that would be ideal.
I have no clue if this is possible, appreciate any guidance or advice.
Tom
Be around 2600kwh a year then real world tbh I would suggest using the pv to heat via the immersion better system long run in my opinion
In the uk tubes arnt the best
Thanks for that input Shaun,
Could i ask you though, could an evacuated tube array feed hot water into the reservoir tank of the Ecodan split unit or be combined with it in a cost efficient way for showers/sinks etc?
Dimplex tubes are fantastic here in the west of Ireland. Multiple installs looked at over the years that were installed as part of a grant scheme for warmer houses and the volume of hot water is exceptional.
They would feed into your hot water cylinder or a thermal battery if you had one fitted
Currently no hot cylinder, only this Ecodan unit.
Ecodan split unit has a 170liter hot water cylinder in it.
It had the provisions to take an input from PV to heat an additional coil.
My question is, could i use this tank and have the evacuated tube array feed this?
Hopefully i’m not driving you nuts Shaun 🙂
  • Informative
Reactions: Ben-gee
