And it wasn't really advice if you read it carefully (it's very carefully qualified), but better than I get from Plumbase who sell me an immersion heater and tell me it's suited to a stainless cylinder and then when I read the instructions it clearly states 'this is for use in a copper cylinder only'.
Now I only trust manufacturers, and only when they put it in writing, and even then I'm sceptical, because most technical departments don't really have a clue; in fact I've spent more time studying the Honeywell ABV than anyone I've spoken to in Honeywell's technical department who only go off the limited information they have [in fairness, they did tell me how to strip it down and reassemble, which helped].
Even Mira doesn't have detailed information on the flow rates for all of its showers at a range of given operating pressures. Then they tell me 'there is a variety of factors' (no there aren't, not when I'm asking for the flow at a given operating pressure at the shower inlet).
Quite honestly, I prefer evidence based on real experience, hence perpetually lurking here.
It’s a great thing to ask questions and I would recommend you keep on reading and reading and reading. Building regs, central heating compliance guide, water regs etc.
BTW your ‘violent tap’ issue. Could be solved with two ballafix turned to 45 degrees yo limit the flow 🙂
Well, I was under the impression that it was considered bad practice to half turn off a spherical isolator on the grounds that this tends to make them seize up? Prior to learning this, I did used to do just that! What's the truth now?
Update.
I tried fitting the restrictor in a 1/2" Francis Pegler tap tail and it seemed to fit perfectly in the bore, but the restrictor was too long for the bored-out length of tail. The restrictors work well when used as intended, but I can't say I'm especially fond of the valves they come with, though I find them acceptable.
There is flexible hoses available to buy used for the hotwater expansion into the vessal. Personally i like to pipe them up in copper
I have piped mine up in copper. It is leaking at the expansion vessel joint. I used a compression to female I think with ptfe. I cannot get it any tighter. Only a slow drip, but still a leak! Any suggestions. Thanks
