A
Aire
Me too and I'm only 31 😉Yeah.. Or even just convection... Lol.. Been out of school too long..
Exactly, I fear that's the case across most trades nowadays. Corners can be cut unnoticeably by most tradesmen because customers are generally clueless and have little interest in anything but the price. I'd have paid the guy double for a quality, craftsman like job but I think, where I live, most people are poor and price is the only thing that gets the sale. I'm not wealthy by any stretch but I place value on quality and in my experience, it's worth sacrifice.I've had many RGI's over the years (including 3 for work in the last 5 years) - I've yet to meet one that deburrs the pipes! To be fair to them, it is time consuming and they are probably usually employed based on the price they give, so deburring would add to their time and cost. However, it would be nice if they were to give the option for somebody who knows what deburring is. I suppose your average joe wouldn't.
Pipe cleaning is usually a given, though. They'd be unlikely to get a good soldered joint if they didn't do so on old pipework.
Did you make this known before the job started?Exactly, I fear that's the case across most trades nowadays. Corners can be cut unnoticeably by most tradesmen because customers are generally clueless and have little interest in anything but the price. I'd have paid the guy double for a quality, craftsman like job but I think, where I live, most people are poor and price is the only thing that gets the sale. I'm not wealthy by any stretch but I place value on quality and in my experience, it's worth sacrifice.
Laco has that trait..... He used fernox flux..... Not a problem, it seemed a good clean flux but my main gripe was that he never cleaned the copper before fluxing, even when obviously tarnished, that left even him doubting some joints when drips appeared after power up.... It was condensation but he doubted his own joints.I doubt many people deburr pipe, its not required.
Any joints I solder and dont clean are green the next day! maybe I use the wrong flux.
Yep, I told him I was fussy, was more interested in a good job and that almost word for word, I've obviously got a budget but I wasn't out to Rob anyone..... Which I thought was a fair upfront and honest approach. He gave his price, I never haggled and agreed immediately, even paid him a £50 tip for at least turning up on time and he was clearly a good worker.... And a nice personable guy.Did you make this known before the job started?
Admittedly all my pipework was new but its still good craftsmanship to clean and all my new joints were routinely cleaned & deburred.I've had many RGI's over the years (including 3 for work in the last 5 years) - I've yet to meet one that deburrs the pipes! To be fair to them, it is time consuming and they are probably usually employed based on the price they give, so deburring would add to their time and cost. However, it would be nice if they were to give the option for somebody who knows what deburring is. I suppose your average joe wouldn't.
Thanks for your input.... I am a fussy bugger but I actually assumed that with all the hype over the essential mandating of gas safe rgi's, that standards were very high..... Needless to say, I've had a rude awakening and now have eroded trust in tradesmen.... Common for me.I see your point about deburring and I don't. You really need to consider what the deburring is achieving. While I myself do like to use a pen deburrer whenever possible, I can accept that in most cases the speed of flow is unlikely to result in significant turbulence. After all, since 22mm has twice the volume of 15mm, it is likely that almost all 22mm application is actually not correct pipe sizing, but over-engineering (but it avoids using obscure pipe sizes that are not readily available). Short of doing a full pipe run calculation, it would be impossible to comment. Very probably, all I'm usually achieving is wasting time.
I worked with a guy once who was obsessed about the need to run pulled bends rather than elbows to a radiator that was right next to the boiler, while on the same system there were radiators at a great distance. All I was thinking was that any reduction in flow resistance from the pulled bends would just mean increased balancing would be required to ensure the distant radiators received adequate flow.
Anti-thermosiphon loops are not that uncommon, and, if you think about it, the need for the vent pipe running from a hot water cylinder to be 18" away from the cylinder outlet and connected by a near-horizontal pipe is to prevent parasitical circulation, one-pipe circulation, unwanted thermosiphoning or whatever you want to call it, so it's much the same thing. But we do all call it different things and I must say that, while I have both used and come across such loops in the course of my work, they were not really explained to me at college and so I'm not quite sure what they are supposed to be called either!
Thanks for your input.. I am a fussy bugger but I actually assumed that with all the hype over the essential mandating of gas safe rgi's, that standards were very high... Needless to say, I've had a rude awakening and now have eroded trust in tradesmen.. Common for me.
Well as far as I'm concerned it's a fail on all fronts but hey ho.... Happy new year...Gas Safe Registration is about making sure that the installation is safe and has been properly tested not so much whether the pipework is pretty to look at.
If you are fussy about the 'finish' on the work to be done then you need to see examples (or photographs) of their recent work to check that their normal working standard matches your expectations.
Laco has that trait... He used fernox flux... Not a problem, it seemed a good clean flux but my main gripe was that he never cleaned the copper before fluxing, even when obviously tarnished, that left even him doubting some joints when drips appeared after power up.. It was condensation but he doubted his own joints.
350....I'd budgeted 500......how much did you pay for the install labour? roughly
Not forgetting I'd supplied everything and even mounted the frame and cut the flue aperture....350....I'd budgeted 500....
