ferroil f30 flow sansor
View the thread, titled "ferroil f30 flow sansor" which is posted in Boiler Advice Forum on UK Plumbers Forums.
archiedale
called to NO dhw unless heating is on, found flow sensor had melted internals... can someone tell me how this happens ?
If it's a 240v microswitch eventually they start arching!!! That generates heat and chattering usually 🙂 Eventually everything fuses together 🙂 That'd be my take anyways 🙂
Would that be a temp sensor not actual water flow ? If so I'd imagine it 's corrosion? 2nd guess any closer 🙂
no diamond, flow swithch/sensor
🙂 Okay so you're talking about the hot water flow sensor. Downloaded the mi's to get on the same page archiedale 🙂. Never seen one in my life but notice that is has 3 wires and is on the 24v side of the PCB. So how does this fella detect the flow of water I wonder, I'm intrigued 🙂 As far as it melting, I revert back to my first guess at arching going on inside, maybe due to water perhaps or dirty switch conections if it turns out to be a microswitch inside 🙂
Reply to the thread, titled "ferroil f30 flow sansor" which is posted in Boiler Advice Forum on Plumbers Forums.
archiedale,
diamondgas,
