Nov 21, 2012
32
North West
Heating Engineer (Has GSR)
Business Name
AHP
Hi. Does anyone know the cause and solution to the f34 fault on a ferroli?
The manual is saying its the low voltage error and to check the supply. Im assuming that its correct as installed and this is a pcb fault. Has anyone had any experience with this fault before i go out tomo?
Cheers lads
Why do you assume it’s ok? A quick google search suggests it’s below 170vac or above 250vac. I’m not familiar with these boilers btw, but simple basic checks are surely apt? Not sure if these are affected by reversed polarity either - so may be worth checking if they’ve had any recent work carried out or a smart meter installation.
Yeah, assumed its ok as no work been carried out on property, we look after these houses for landlord. Boiler working fine yesterday. Obviously first task is to check voltage at board but iv got a feeling itl be fine as it was when installed a year ago. Just wondered if anyone experienced this fault and could give me a heads up as to what may cause it. Reversed polarity il look into, il report back, cheers
