C
combo
Went to a Ferroli modena earlier for a basic annual check. Gas rate was fine, 32kW. The Co reading though went crazy...had my kane 455 bleeping like mad..Co in the hundreds, before the ratio even got to 0.008. this was done thru the test point on the combustion case ( liitle grey stoppas that you pull out ). Cleaned Heat ex and gave it torch and smoke match tretment ( clean anyway ) and checked primary air ports..clean. Ran test again, exactly the same. removed combustion cover...now test was okay. With cover removed I played about with analyser probe and if i stuck it up into where air intake attaches to boiler, everynow and then it was picking up 6-10 ppm Co and giving a ratio valuse ( 0.0009 ).....is this test enough to indicate a dodgy flue or might these just be stray wisps of POC's from the burner chamber with the cover off ?
