View the thread, titled "Few combustion questions ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Mr_Hickey
I'm really stuck, searched google and looked throughout the corgi book
1. What level of CO2 in a room could critically affect combustion of a gas-fired asppliance
a - 100ppm
b - 300ppm
c - 1000ppm (My answer)
d - 15000ppm
2.CO can migrate in which of the following ways
a - upward via a stairwell
b - downward if thermal conditions outside the source room promote mixing
c -through roof space
d - all of the above (My answer)
3. The max permitted co figure specified by the WHO in a room may be exceeded
a - if there is no has-fired appliances
b - if the gas fired appliance is on
c - for short term use of flueless appliances such as cookers
d - the room in which the appliance is located is adequately ventilated (My answers)
I would say
a
d
c ( my reasoning comes from the training notes for CPA which gives levels for testing a cooker which are a lot higher than the 10ppm for rooms)
B as most boilers will chug out at 300ppm for short duration? If it's an open flue or flue less 100ppm could be 3 smokers and poor vent?
d
c
Reading own answer first one probably A
Thought co2 was measured as a percentage ? If you mean co most m.i's except levels up to 200ppm if the co2 is correct on new boilers
Reply to the thread, titled "Few combustion questions ?" which is posted in UK Plumbers Forums on Plumbers Forums.
