smtplumbing
we bit of advice here guy, Fitting a Worcester 29cdi boiler at the weekend in a garage, fitting a vertical flue with a flat roof flashing on top of a garage felt with wood underneath, Normally i just get the roofer to do this but he is on holiday. The customer has been at me it better not leak etc. once i cut the hole in the roof and put the flashing on do you guys seal it underneath the flashing to make it water tight or do you tack it down to stop it lifting in the wind
steven
I bed it down on a waterproof mastic and then gob a load of flexacryl around and over the flashing.
[video=youtube;0tzJp0lbKuU]http://www.youtube.com/watch?v=0tzJp0lbKuU[/video]
If done properly, theres no chance of it leaking! I would not waste money on a roofer! Probs easier than a vertical flue through tiles.
Never done either of these. I know now how to do the flat roof but a tiled one? Whats the trick there? Can you drill a pilot (I would have thought the tiles would move making it difficult) and then go on roof find pilot hole and move tiles? Need to put new boiler in my house soon and it will be through tiled roof
Use a lead slate to replace tile removed to insert flue. make sure you interlock tiles properly, worst type of tile is the 70/80s concrete ones that dont overlap, lead slate needs support underneath to work properly and some lead/brick silicone sealant is useful here.
Mutley your post made me cringe in terror at the thought of you perched on a roof drilling a pilot hole! Is there any local installers you could work with on a vertical install?
work from below, screwdriver out under tile, hop on roof via tower and roof ladder, find screwdiver and whip off tile with slate ripper or if horrible concrete style tiles, hammer through middle of said tile, no overlaps so not an issue🙂
but make sure you cover the exposed flue below the tiles! I learnt the hard way on that!
Ha ha sorry mate, I meant drill from inside and then look for pilot bit on top. I do know a guy but would rather not use him. He is a bit of a beast and breaks most things.
I don't mind roofing. I slated a roof before. Like lame said, scaffold and roof ladder
So do you only remove 1 slate or tile? When I have looked at a few out of curiosity, it looks like more than one has been removed. Does it explain it well in the flue kit instructions?
flue instructions tell you how flue fits, you really need to be shown how to do the slate and roofing by someone who knows or your custards will be ringing when it rains. Re your question NO, heeheeheehee there go the ribs now
The MIs for a vertical flue tell you how to put it together and how far you can run it.
it isn't that hard get up there and get learning, use common sense regarding weather protection and you will be fine. If in doubt pour a bucket of water down the roof.
fit it level and clip it. I can't stand seeing v flues lop sided
E
1K
E
