Hi all
I'm after some recommendations for high quality manufactured flexi-hoses.
There are a number of flexi-hoses used in my house and I suspect that they are all over 10 years old, so would like to replace them as a pre-emptive measure before they pop (all on mains pressure). Unfortunately they're all in awkward places which would most likely require removal of hardware (bath, vanity cupboard) if I wanted to replace with copper/pex fittings, which would be the ideal resolution but unfortunately the financial situation won't accommodate that, so I'll have to replace on a like-for-like basis.
They're all 300m with standard 15mm & 1/2" threaded connectors, but a couple are of the 22mm push-fit type.
I'd like to think that there are varying degrees of quality when it comes to these, so I'd rather spend a few extra quid and get as best quality as possible (which is sometimes demonstrated by a longer guarantee).
The Flo-fit hoses on ScrewFix appear to have a 50 year guarantee, but when you dig into the T&Cs, they actually state "Products such as flexihoses and tap connectors, have a standard 2-year warranty." Similarly with JG Speedfit - they advertise a 25 year gurantee on the SF site (which I think is now 50 years too?), however the smallprint in their T&Cs state "All other plumbing products such as flexi hoses, valves and tap connectors, have a standard 1-year warranty." Again with Flomasta - SF website states a 10 year guarantee, however their actual website states that this only for radiators, and fill & flush valves.
Are there any brands/manufacturers which anyone would recommend? Preferably with as long a warranty as possible (I understand that in Oz they all come with 10 year minimum now) Similarly, are there any which should be avoided?
Another question to ask is whether the warranty covers more than the cost of the hose? (If a burst occurs when the building is unoccupied the damage will be measured in thousands of pounds.)
According to
the Australian insurer IAG, flexible braided hoses accounted for 22% of water damage claims in Australian households (mostly kitchen and bathroom damages) in 2016.
IAG described flexible connectors a ‘ticking time bomb’ and put warnings on its website informing home owners that flexible hoses have a lifespan of between five and ten years, and advising that they should be checked by a qualified plumber every two years.
My advice is not to use them but, if you must:
  1. Use only genuine hoses supplied by high-quality European makers that are certified to comply with the EN 13618 standard
  2. install them carefully in accordance with the manufacturers instructions (no sharp bends, no twists or kinks)
  3. check the insurance policy will cover damage caused by failure
  4. inspect every two years
  5. replace every 6 or 7 years or as specified by the manufacturer
This list is based on research and literature reviewed in
https://doi.org/10.1016/j.engfailanal.2019.104327
I'll also add 'install a PRV limiting the supply pressure to 3 bar' and make sure that the system is not susceptible to water hammer to the list because of a couple of incidents I've seen myself over the years.
According to
Thanks Chuck - this is really helpful. I had seen the IAG page which made me a bit twitchy...
I'll look into the implications of the PRV, which is definitely a good shout as there is sometimes a hammer on one of the pipes leading to the 22mm flexi.
Regarding the "high-quality European makers": from your experience, which would you recommend?
Thanks again
