H
hunterseye
Read a response on here about not using flexis on a gravity system. Why is this?
The only legitimate use for flexi's is to daisychain them together to aid in the training and chastisement of love slaves.
We could lay a ring of them round System3's house and see if he ever comes out again!
Too late Croppie he's deeed.
Probably playing a harp with strings made from shiny braided sheath with a flexible rubberised tubular core.
Nope, never been to Portadown.So Colin's in purgatory?
Lee, you've either been on the sauce or your typing on a wee phone. But being Scottish I understand what you're saying. :whatchutalkingaboutPoorer col is going to be having nightmares all weekend after reading this loy
I've risen from the grave just like some bloke did a few thousand years back, but instead of rolling a boulder, I'm doing the modern version and there's a big tub of Plumbersmate making it's way down Stirling Castle at the moment.
You horrors designed my coffin with flexi handles! When it was lifted they burst, ah well nothing changes there.
No doubt revived by way of applying compression to your vital parts system3?
Exactly that. Reduced flow rates and on older properties where the hot water temp can go above 65 degrees, the rubber becomes brittle and bursts. That is also a reason to never standard ones on a heating system.flow rates and temps(solid fuel) i would say.
Reply to the thread, titled "flexi's" which is posted in UK Plumbers Forums on Plumbers Forums.
