A
Access Gas
Hi guys,
Ive been registered on here for a while and never really used the service but it looks like many minds are better than 1.
I have a property with 6 rads and 1 cylinder s plan system boiler the upstairs rads have issues.
Nannys room - TRV shut off the return pipe gets hot, when the TRV is opened the flow pipe gets hot fast and the rad heats up, the return pipe goes cold but doesn't warm up
I do expect the return to be colder than the flow but the difference in temperature is more than 20 degrees.
Kids room has the same issue with temperature difference and sometimes doesn't even come on at all.
Main bedroom has same issue with flow and return temperature difference but not all the time, somedays the difference is only 5-10 degrees after being on for 10 minutes.
I have vented the flow and return pipes individually thinking there are air locks as the nannys room radiator collects a lot of gas.
I have suggested a powerflush but in all honesty I don't think that Is the problem.
What is confusing me is why the return pipe in the nannys room gets hot when the rad is turned off, if there was letby to the TRV surely the flow pipe would be getting hot.?
it seems like there is a flow coming through both pipes but one has more force than the other. In my mind if a flow pipe is connected to the return surely it will just go back to the boiler like a bypass valve.
Hope someone can give some advice-
thanks in advance
Tan
thanks in advance
Tan
