View the thread, titled "flue seal leaking water" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
A
ash121
we have a High level flue outlet kit fitted to the boiler ideal logic combi plus i have noticed water dripping from the internal flue on to the ground where the internal pipe connects to the flue elbow/air terminal, upon closer inspection it seems to be coming from the seal where the internal flue pipe connects to
The flue is sloped back to the boiler, I have spoken to my plumber about this who has advised he has come across this before and has suggested that he could seal it up with sealant as the seals are weak and prone to causing leaks
Is this fine to do?
Reply to the thread, titled "flue seal leaking water" which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
