A
ash121
we have a High level flue outlet kit fitted to the boiler ideal logic combi plus i have noticed water dripping from the internal flue on to the ground where the internal pipe connects to the flue elbow/air terminal, upon closer inspection it seems to be coming from the seal where the internal flue pipe connects to
The flue is sloped back to the boiler, I have spoken to my plumber about this who has advised he has come across this before and has suggested that he could seal it up with sealant as the seals are weak and prone to causing leaks
Is this fine to do?
dont know how long that shall take though, and i guess they shall just give another seal to fit, shall advise the plumber to seal it in with silicone sealant and if it leaks again will put a complaint in, cheers
Wrong,
How are Ideal to know they have a problem if enough people refuse to tell them?
Tell Ideal (complain) use sealant as a temporary measure until they fix the problem, your GSR should know this is the way to go which suggests a lot of things to me.
Upvote 0
it seems to be a common problem, as yet dont think any manufacturer has a solution for a permanent fix, it has been sealed in with high modulus clear silicone sealant
Upvote 0
