A
AndyN01
Hi all,
First post but thanks for all the brilliant advice I've been piggy backing in the past.
Not too sure if this is on the right forum - if not can a moderator move it to the right one - thanks
I have a coal boiler - Trianco 45K BTU heating the central heating only.
CH is "normal" pumped open system with 7 rads, F&E tank in the loft.
There's a gravity loop (28mm F&R) to keep flow through the boiler with an open heat sink rad (no lockshields TBOE).
System has been in several (many?) years. Rads have been taken off and flushed out (loads of black crud - lovely! At least it's not all over the carpets).
This is where I'd appreciate your help.
Planning on running X400 for a couple of weeks (longer?) with the boiler fired up and heating on.
Obviously, because it's a coal boiler I can't just turn it off but I can rake the fire out.
Is it better to drain the X400 out hot? Does that help or doesn't it matter if it's cold?
I'll wait for the boiler to cool (don't want to hit a hot cast iron boiler with cold water :wink5🙂 before refilling the system with plain water then draining down (once? twice? more?) then refilling with X100.
How does that sound?
Thanks.
Andy.
Thanks.
Andy.
