Re: Outside flue hole not filled in by plumber
If you plaster the inside and put rubber seal on external what are the actual odds of a poc issue??
another concern would be water ingress, if the rubber seal didnt make a fully water tights seal you could get damp problems etc, more of a problem now boiler flues rise upwards .
Kudos good point !
