fused spurs
View the thread, titled "fused spurs" which is posted in UK Plumbers Forums on UK Plumbers Forums.
T&E cable from a spur to a boiler is fine, providing you use a wiring box, or another spur to take white 3 core round cable into boiler
So have you taken 1.5t&e into the boiler
I havent done anything, this is just one ive came across that has got me thinking. But yes t+e into boiler. Mi's say at least 0.75mm pvc insulated cable....dosent say you have to use flex.
To throw a spanner the works, you could feed an FCU with a run of 1.5mm t+e clipped direct from the consumer unit and protect it with a 16A 60898.
dude it sounds like your out of your depth, from the fused spur to the boiler use flex looks much better and you wont have any problems with the glands on the boiler
That's because they don't make 0.75mm flat t&e
or if you got a bit of 1mm pyro knocking about you could use that as well, might be a struggle to make off for most folks though ;-)
That was why I asked the question. 2.5mm from the board on a 15amp 3036 rewireable fuse to the immersion. Then a 1.5mm from the spur to the boiler with a 3 amp fuse at the spur. Just thought the 15amp at the board should be changed to a 6amp. Wasn't sure with the 2.5mm t+e.
You can't spur off a radial circuit!
Flex is used because of the fact the front control panel is made to move for access, flat t&e is used for fixed wiring, and I can't remember pyro being used for anything that could move.
You can spur, and extend from a radial circuit as long as the cable is sized correctly. Its not great practice to spur from an immersion heater radial though as the OSG appendix 8 says that water heaters of 15l capacity or more should be on there own circuit.
Just for the record I never wire boilers hense all the questions/confusion!
Croppie are you saying that you cant change an immersion for a fcu?? Thought this was standard on refurbs to use the old immersion for the new boiler?
The osg says about spurring off ring mains, one spur per outlet (or double outlet)
Categorically states not off radials.
you can when you remove the immersion/cyclinder but you can spur off an immersion circuit with the immersion still in use
So what if the boiler cable is totally seperate/nothing to do with the fold down panel?!
Course you can do that, senseless not to. But you'd be changing the immersion isolator to a FSS to feed the wiring centre. Any remote isolators, such as in the kitchen, for example, would need to be turned into a junction and blanked off.
This example is just for a combi. so cylinder gone, immersion switch changed to fcu for combi.
Have to disagree there, although not got an OSG to hand to check. Spurring from radial circuits
when fused and wired correct is no issue at all. A 16A radial circuit run in 2.5mm T&E for instance cannot result in overloaded cable if the spurred cables are in 2.5mm T&E.
Reply to the thread, titled "fused spurs" which is posted in UK Plumbers Forums on Plumbers Forums.
stratplus,
stratplus,
