I wouldn't run a flex that sort of distance, in this case I would use 1.5mm flat t&e from the stat to a connection unit at the side of the boiler and then a flex from connection unit to boiler, again I would use 0.75mm flex.
you missed a point
Sounds fine to me providing the run is going to a 3amp fused spud outlets for first, and it's all 230v. @3amp you could split / chockoff the lighting ring .That was why I asked the question. 2.5mm from the board on a 15amp 3036 rewireable fuse to the immersion. Then a 1.5mm from the spur to the boiler with a 3 amp fuse at the spur. Just thought the 15amp at the board should be changed to a 6amp. Wasn't sure with the 2.5mm t+e.
Sure. But you could have even used a 45amp outlet providing you regulate the source @ that minimum power output..!!Not good practice when it's labelled lighting on the CU!
There is nothing to stop you regulatory wise wiring your whole house in flex if you wish.
What's an OSG?Did you get the OSG with that
What's an OSG?
Thanks.!On site guide
Reply to the thread, titled "fused spurs" which is posted in UK Plumbers Forums on Plumbers Forums.
