gas cooker
View the thread, titled "gas cooker" which is posted in Gas Engineers Forum on UK Plumbers Forums.
F
franz
have just bought a repo house.gas cooker is rancid.
I want to throw it out.
can i simply turn off the gas ,and undo the connection at the hose where it connects to the pipe and turn on the gas again?
In theory, you should be fine, but the bayonet fittings on the pipework side have a spring-loaded part which should seal the pipe. However, there is no guarantee that it wont pass, so best be safe and get it capped before the hose.
And it should be done by a Gas Safe registered fitter, who will do a soundness test on the whole system.
It really isnt worth taking chances with gas. If you are away from the property for any length of time and there is a leak, then it is an explosion waiting to happen.
i agree with the othere posts, and would add it is a very good idea to have the whole gas system, including boiler and fires checked when you taks over a new property as you have no idea when it was checked before, and unfortunately i have to add even if you have paperwork "proving" it has been fully checked, it only "proves" you have a bit of paper, get it checked out by your own gas engineer then you know it is safe
bayonnets are designed for temporary disconnection for getting in behind ovens to clean, not a permanent means of isolation. Best to do what has already been mentioned in previous posts
As long as the connection is the spring loaded bayonet type then you can disconnect from there.
There is no requirement to cap off the bayonet and as long as there is no leak of gas can be
left as is.
left as is.
i think you will find mate that wats been said earlier is correct and is only temporary, sure when i done my gas it said if it was being left for any length of time after 24 hours it has to be permenently capped
no its there so it can be disconnetced for the customer to clean behind then put back , but like has been said it is not meant a permanent way of isloating the gas supply
bayonnets are designed so customers can remove cooker to gain access to clean, they are not designed for a permanent means of isolation, should be removed and capped as previously said, because bayonnet fitting is a mechanical fitting and can fail.
they still cant assemble hose to cooker body, do tightness test etc make sure its working safely ventilation etc
but then again with the kit Pee &Poo are sellin now maybe alot of DIY installs
If you don't have your cooker ticket you cant install cookers or hobs. The only thing regarding cookers the customer can do is disconnect the bayonet temporarily as has already been said. For everything else you need to be GSR.
You can do hobs without cookers , your basically tho installing a cooker if your connecting hose to bayonette, so an owner will be doing illegal work
i always have to assemble hose into male or female adaptor which then i connect to the cooker, so its not just as simple as plugging a hose into a bayonnet
You can fit hobs without your cooker ticket? That's a new one on me.. Id look further into that if I were you.
No need to look into it had it straight from gas safe as already asked in the past , hob on rigid pipework .
Erm.. I would argue that a hob is a cooker as defined by the standard BS6172:2010
argue it with gas safe then ,
a hob is a hob not cooker hence name hob !!!
like i said been told it from the horses mouth so to speak !
I dont need to, Its in the standard that is available on their website. You might want to check it out, what would you class an gas oven as then?
GSIUR reg 2 par 22 definition of work, "but the expression does not include the connection or disconnection of a bayonet fitting or other self-sealing connector."
this is as said only to be understood for the short term, such as removal for cleaning behind.
i dont need to ,like i said inquired to gsr about fitting hobs, passed my reg as you do and they gave me all clear good enough for them good enough for me .
Nice to see its clear as crystal as per usual ,,,talk about sitting on the fence.
So you are fitting gas hobs without CKR1? It would be interesting to know Gas Safe's logic behind this, especially when it comes to gas hobs which can be fitted with flexible hoses.
have on site yes , my own works no as cant be bothered to bum about for £50 .hence why never bothered with cooker ticket .
I fit them for IKEA installers, get £100 a pop and was always told I needed my CKR1 hence why I'm a bit taken aback by Gas safes response.
I have been posting on this type of forum long enough to know that there may be
others that might know better and plenty that know little ready to shoot me down
in flames if I get it wrong.
I try not to post unless I am sure I can back up what I say for this reason.
GSIR Reg 6(3) Any person who disconnects a gas fitting shall, with the appropriate fitting, seal off
every outlet of every pipe to which it was connected.
Guidance to this regulation goes on to say ..................A self- sealing coupling, eg on a cooker connection,
does not need to be capped off, ....................
It also goes on to say that ................However, it should be checked that any disconnected coupling is
is not leaking gas ..................
Reply to the thread, titled "gas cooker" which is posted in Gas Engineers Forum on Plumbers Forums.
franz,
gaspastemania,
