gas fire regs gather hood/closure plate?
View the thread, titled "gas fire regs gather hood/closure plate?" which is posted in Gas Engineers Forum on UK Plumbers Forums.
We had a metalwork company make up some custom fittings that are just small Enough to slide up inside the liner, and we sealed it with fire silicone at the joint with the liner, and screwed the plate with silicone seal too.
Looks good but, always helps if it has a tappered transition into the liner though.This reduces the resitance of flow up the chimney. It will probably work ok. flue flow test will find out.
Double boarded then skimmed. According to Fire regs I think, this is dot and dabbed onto existing masonry. Apocalypse proof, Satan proof!
The above installation (fire plasterboard) This is not the correct fire resistance plaster board,
it should be pink in colour as my pic below (This is the correct one that should have been used).
NOT THIS ONE
from
topdog
next issue is whether a plasterboard fire enclosure meets gas/building regs as a suitable material
Double skinning provides the same fire resistance rating as a single skin on pink board, been accepted by ds on jobs for years. Can save you money if you have left over standard boards. Also I did mention it was dot and dabbed onto existing masonry so there's no timber behind it to catch fire. I only posted the photo to show what I was talking about in the original question, because the answers weren't quite what I was looking for, we got there in the end though, thanks for all the answers anyway.
In fact I have seen the following para in many risk assessments and FSOs that I have worked with are in agreement that for existing buildings, this would be acceptable:
"...overboard the existing ceiling or apply directly to the joists either one layer of 15mm fire rated plasterboard or two layers of 12.5mm fire rated plasterboard with overlapping edges, jointed and sealed, installed by a competent person."
No no no no not plasterboard in a chimney system. tell me its not! Suitable material for flues/chimney's.
I always use LS board, FIRE RATED PLASTERBOARD IS USED ON THE FRONT OF THE CHIMNEY BREAST ONLY (Dob & Dab, Then skim plaster over board.
LS board used internally.
topdog
you seem to be discussing how to finish a ceiling to a finish to give an hours fire resistance, ceilings arent fireplaces and builders openings! it also mentions competent person!!! nuff said
Thanks for all the advice I just posted the photos to help clarify a few things, anyway the building inspector gave it the nod so all's well that ends well. 🙂
Interesting talk about plasterboard. On the chimney breast externally in the room all OK. Within the chimney opening it is not suitable. General fire resistance on plasterboard is 30 minutes. This is tested under conditions in event of a fire, this does not confirm suitability as a long term fire resistant material . Plasterboard will degrade at a fairly constant rate when exposed to long term exposure to heat and moisture (the conditions we find in chimneys). The best solution if you need to use a board, is a proper fire proof boarding, like superlux, masterboard ect.
I was involved with assisting an HSE prosecution against a fairly large business some years back, wher the contractor constructed plasterboard in glback boiler openings on about 100+ properties. They got very large fine and had to strip all the boilers out and brick the side wall openings up properly.
Reply to the thread, titled "gas fire regs gather hood/closure plate?" which is posted in Gas Engineers Forum on Plumbers Forums.
OGBUzzard,
Reg Man,
