plumbdoctor
Hi all
having a argument with another gas safe engineer about when fitting a female iron to the gas hob connection under the work top do you guys use a fibre washer ?
Depend on the fitting.
If it's a taper thread and the seal is made by the threads use ptfe or paste. (A true iron threaded fitting)
If its two flat machined faces designed to take a washer (like a tap connector) and compress it then use a washer.
It's probably the first one. If you try using a washer on iron threaded the washer will probably be destroyed as the two parts pull it in either direction as it is tightened.
