thereisawizza
671
188
43
Hythe, Kent
Evening all!
Called to do a service yesterday, new customer to me. Went to meter to carry out gas rate, found front half of semi-recessed box but back missing, meter in cavity. Also gas outlet pipe from meter run down in cavity before entering screed.
Here's the plan:
Remove meter, anaconda & governor (as a wonner) and remnants of box. Brick up and fit surface box, run new external pipe to boiler.
Do I need MET1? This job needs to be "whiter than white" as I created merry hell logging this AR fault with SGN yesterday as they were contracted by Scottish Power to do a meter exchange 3 months ago, which they did, giving it a clean bill of health. The customer has raised a complaint with GSR about Scottish Power as he no longer has any gas.
Yes you do. You are moving (or uninstalling and reinstalling) a meter, so you need the ticket.
As far as SGN are concerned they would see it as a chargeable job as they didn't fit the meter originally, very kindly estimated to my customer £400-800. I've pushed the point that they were the last ones to work on it which makes them responsible; the customer is stuck in the middle and thinking about going to the press!
Fair enough. Do you know anyone with MET1?
The OP is responsible for the downstream only.
B
2K
M
