O
on31ll
Got a gas meter under my stairs smack bang in middle. So ideally best to het gas meter moved. Basically there a 2ft space under the floor so instead of paying stupid money to get it moved 15 inches can i get a GSR obviously to drop the pipe to the sub floor since ins propped up on bricks then add pipework after the ECV thats there then pop through the floor and add a secondary ECV ? Then have regulator and meter ? That allowed ? And would first ecv need to be accessable ?
Does that make sense to you guys ? I need to get a mate that works for united utilities !
In a word...no. The ecv needs to close to the meter. Not sure exactly how far. The meter shouldn't be on bricks either, it should be on a proper bracket. Call your provider 0800111990 and they'll do f.o.c. Make him a cup of tea, give him a kit kat and ask what can be done.
Where does it say in the regs that an ECV needs to be near a meter?
So could this be dropped under the floor rerpute pipework then come through an have a secondary ECV ? Would the first one need to be accessible ?
Finding it hard to picture this, however the meter needs to remain accessible for reading etc.
Go on then what's the regs. I personally need one close by to perform a drop test.
6.3.1.1 All primary meter installations shall incorporate a meter regulator in close proximity to the meter.
6.3.1.2 The meter regulator shall be sited as near as practical to the outlet of the ECV.
6.3.1.3 The interconnecting pipework between the meter regulator and the primary meter shall be as short as practical.
No distance mentioned.
And you can't fit a meter under a floor as it would not be classed as accessible. 1st time they came to read it, it would be reported.
As always Tamz puts it far better then me and quotes the exact regs!
nooo not put meter under floor just the first ECV.
basically the upstream suppl comes into my house in steel on the actual subfloor. theres about 2 ft space from sub floor to actual floor but the pipe is held up one end by bricks to just hold it up so the ecv sticks through the floor.
my question is can i drop the ecv to under the floor and alter pipework and add secondary ECV next to the meter giving the meter a new position ?
I'd be tempted to call Transco out as the incoming pipework should be fully supported and not propped up on bricks. You never know they may sort it for free!
I think you would need to open your wallet and give all the contents to the national grid for this job.
is the meter hard piped with no anaconda?
im asking can it be under the floor or would it need to be accesable ?
and no it has a anaconda
just seing if i can get away with it ! im not majorly botherd its just an easier job if it can be done and then opens up the space
Untitled.jpgwhat it is now
