F
FlowGas
Hi everyone, just need a little bit of advice. I'm running a new gas line from the meter to the cooker above ground which will be supported against a side wall , as previous pipework is underground. There are two kitchen cabinets between the cooker space and the pipe route I'm planning to take. Is it possible for me to take the gas pipe through the cabinets and box off the pipework in the cabinets, clearly mark it so protected up to the cooker?
Should mention that I'm newly qualified GSE.
I'd send a link to gas man or redsaw with your details then repost in the private area of the forum fo r a answer.
as roger said, send a pm to either gas man or redsaw with your details gs number etc., you will have to answer a couple of gas related questions to prove you are gas safe then you will be admitted into the private gas safe section where you can ask gas related questions.
