sheilawasadiver
Hello everyone
Apologies if I've posted in the wrong area, feel free to correct me :sorcerer:
Anyhow, I'm a private renter and wanted a second opinion. I've been given a number of gas safety certificates and have two Qs:
- Is it possible to undertake a gas safety check and issue a gas safety certificate for a device that hasn't yet been installed in the property? (i.e. can it be done before it's connected to the gas mains and signed off as 'safe'). Sounds like a stupid question, but I wouldn't know. The Gas Safety certificate I have was issued for a Logik hob, but there's a receipt for purchase of the hob which has a date one day after the certificate was issued.
- If not, where/who would I go to validate the certificate? Does Gas Safe Register hold them centrally? The engineer is Gas Safe Registered but I wasn't sure if there was a central repository for gas safety certificates.
Many thanks
NOT possible
Could be a simple mistake such as the guy forgot what the correct date was, I`ve done it before on general paperwork.
And welcome to the forum by the way.
Yeah, always feasible.
Thanks for your response 🙂
Could it be a new hob to replace old hob exactly the same and cert was issued for the old hob?
However if the original hob had failed inspection and needed replacement then it shouldn't have had a cert issued. I'm with the opinion that it was a simple date error, however OP is in his rights to get it reissued for clarity.
I have a Gas Safety certificate from Nov '13 for a Baumatic hob, then one following for a Logik hob in Jul '14. No mention on Nov '13 of the hob being a duff.
anyway a new appliance is not subject to needing the certificate until its been in for a year
Thanks. :45:But a gas cert wouldn't have been issued for a hob that wasn't yet installed in the property, surely?
Who installed the new hob?
The same person did both certificates and installed the hob according to the invoice, but as previously stated the hob was purchased the day after the gas safety certificate.
Thanks!
is there a safety concern with the hob in question?
1st thing to do if you wish is to contact the engineer and ask about the hob. It sounds like a case of the wrong date being recorded as the date are close to one another.
is the receipt a printed one from the shop that sold the hob?
Hi there, thanks for responding. It's not actually my hob. There was a water leak from my apartment into the apartment below, which is said to have damaged to hob beyond repair. Got the receipts (yep, printed from the shop) and gas safety certificates, and insurers questioning inconsistency in dates. Just trying to sort it out! 🙂
