Jan 27, 2019
DIY or Homeowner
Hi, over the last couple of days I’ve noticed that there's water dripping from the corner of the boiler. This only happens when the boiler is in use. Up to now the boiler is functioning and heating water and central heating. I would just like to be advised whether this is going to be a major problem or something that is fixable. It was installed March 2007. The drips are dripping from the locations circles red, the white pipe is the waste water pipe. Thank you
Call an enginner to come look at it, if it's only leaking during use then you may have an issue with condensate sump or trap. Don't ignore it though, condensate water is corrosive so the more you leave it the more damage may be done.
  • Agree
Reactions: Harvest Fields
Thank you, would the trap be located internally or is it visible underneath (anywhere on pic). I’m not going to mess with it, it’s so I can observe until I can get an engineer. It’s switched off at the moment and will only use it for a short time later when temp drops.
‍♀️ Oh yeah. Suppose I can’t complain really this is the first problem I’ve ever had with the boiler it’s been quite good to me. Maybe it’s time to upgrade. Is nearly 12 years old for a boiler?
Probably more like minimal usage. From about April to October it’s never or rarely used, I still have a hot water tank with a good old Emersion heater and electric cooker so I don’t need to use gas in the warmer months.
It's a lot cheaper to heat water with gas than by electricity. My leccy costs 6 times per unit what my gas costs. It's fine to run a boiler on HW for, e.g., an hour a day even when the CH is not required and this is usually what gives best value.
Reactions: Riley
Well it’s still full of water mate seals can give etc there is a head of water pressure wise still upon it or It could be a sealed system making it under 1-1.5 bar pressure constantly
Hi, I’ll be honest its a prepayment gas meter so when it runs out then I don’t top up Til it’s cold. Plus I hated going in the cuboard full of spiders. It just became an annual thing I didn’t then. However now I’m smart so my electrical and gas are combined and I don’t run out. It will be interesting to see my annual costs. Monthly costs are shocking ha!
Back to the boiler. If the problem is the condensing thing. (I know you’d need to inspect it visually in person to establish the problem properly) Do you know what the average cost is usually?I know it varies depending on company/GSE used. Just a rough idea
Also is it a minor repair or major. Thank you all
Be aware I only mentioned the possibility of an issue with your condensate based on you saying it only leaked during use. It could be numerous things causing it so please don't go questioning your engineer if he says something different. The last thing he/she will want to hear is "well that's not what Craig on the plumbing forum said" 😀.
Ha no I wouldn’t, I just wanted an average price so i have an idea.
The boiler is currently in use, it’s just occasional drips. But I’ve measured the water collected in 24 hours around 120mls give or take a drip. ( also the water appears to have a a yellow/orange tint).
