T
trokey
Any help would be very much appreciated
Glow Worm 30 CXI central heating comes on with no demand from thermostat and even remains on when cenral heating is switched off - I have had to turn power off to stop it - No fault code displayed - also the radiators get warm when hot water is used when i have managed to temporarily switch the boiler back on without constant heating (then in middle of night came on again by itself) ?
Hi, sounds like the motorised valve is staying open, letting water pass into heating, therefore rads get hot when taps tuned on, & when boiler calls for hot water preheat. You probaly notice you hot water isn't as hot.
Thanks for your diagnosis- much appreciated-yes water only gets really hot when tap only half on - can the motorised valved be excersised and work again or is it best to just replace it?and is it an easy replacement or am i best calling a plumber
It's best to get a Gas Safe Engineer who specialises in service & repairs.
Hi trokey, did you manage to fix your glowworm , ive just had the same thing happen to our boiler, I installed it 5 yrs ago and its been great up to now, but same symptoms as yours.
Was it the motorized valve?
Thanks, james
People ask questions you try to help them but they rarely get back on and let you know the end result its ignorant
