How's it going. I am GSR (number 3042933), I've sent an email to redsaw and haven't had my details updated yet. One of my customers has a glowworm 30cxi (gc 4704724) and with no demand and power on the fan just continuously runs at full speed. I've checked continuity through the over heat which is ok, checked resistance of flow/return temperature sensors, 8.5kohms which is ok for the temperature. The boiler doesn't have an aps. No fault codes come up, the boiler just displays the system pressure of 1.3bar. I switched the boiler to maximum rate on the potentiometer on the interface board which displays the fan speed, which was showing 55, near enough max rate for 30kw. Also the boiler doesn't really do a lot when you put a demand on either - fan just continues to run, and nothing else.
I'm thinking PCB fault, any ideas?
