Glow Worm Flexicom 15hx Leaking condensate
View the thread, titled "Glow Worm Flexicom 15hx Leaking condensate" which is posted in Central Heating Forum on UK Plumbers Forums.
I have a Glow Worm Flexicom 15hx that is leaking what I assume is condensate from the circled area, is this likely to be from the part of the flue that could also leak CO gas? Would the fix be as straightforward as replacing this plastic part if that is the source of the leak? Thanks!
Reply to the thread, titled "Glow Worm Flexicom 15hx Leaking condensate" which is posted in Central Heating Forum on Plumbers Forums.
TomGib,
Gasmk1,
