sonoi
Hi Guys,
Been having a nightmare weekend...Had a leaking radiator on my central heating system on saturday, so called out BG as got the homecare cover. BG sorted out leak then went to look at the boiler. He said there are signs of rusting on the boiler metal case / cover itself, and said he had to push a metal screwdriver into the rust as safety check. Sadly the screw driver went straight through the boiler has been disconnected as deemed dangerous due to possible carbon monoxide leaking out throught the boiler case.
The boiler is a Glow Worm Spacesaver 60F, and about 20yrs old. It is a standard condensing conventional boiler, open vented, with cold water tanks in loft, and immersion heater in airing cupboard.
The BG guy looked to order a replacement boiler case on his system and said not available as too old. He said unless I could source a brand new boiler case myself, the boiler would need replacing!! 🙁
Where is the best place to look to source a new boiler case for a 20yr old glowworm boiler?
I had a BG sales person come over today to quote on a new boiler, replace like for like ie put another condensing conventional boiler in. They recommended Worcester Bosch Greenstar 24Ri, power flush, magnabooster2 filter, said i need new 22mm gas pipes from gas meter to kitchen as current is only 15mm, all installed, total cost of £3,100...
Guys, please could you give me some advice, is sourcing a new boiler case impossible for a 20yr old boiler, and if so, does the british gas quote sound reasonable, and is a powerflush really needed as when the BG guy drained the leaking radiator yesterday the water was clear...
Thanks in advance for any help!
Regards.
Regards.
