Gravity to sealed question
View the thread, titled "Gravity to sealed question" which is posted in UK Plumbers Forums on UK Plumbers Forums.
GQuigley67
got an open vented electric thermal store I want to convert the heating system to a sealed system due to pipework being above the F&E. boiler is in airing cupboard and pipes drop from loft to rads, the boiler is 9kw so I need a plate heat exchanger, was wondering if taking one from a Combi would work if somehow one had suitable connections, sure I have about 5 combis in my lock up.
Failing that, anyone recommend a reasonably priced PHE up to the job ?
No it won't sorry and bss do some very good boss branded ones
So you want to keep the thermal store open vented ?
The boiler needs to be open vented, I need to change the heating to sealed so seperarion with a PHE is required.
Kinda messed up on my design and was in sealed system auto pilot mode not realising it was an open vented thermal store, so system has major air issues now, hoping it's not gonna be too much of an expensive mistake, heating works just major gurgling at thermal store. Still money on the job for couple hundred to convert but hoping PhE is below £150 lol
If their cheap then I'll just go to BSS and buy one, least they can assist with what adapators I need. Would hate to order online and it wasn't BS
Am i missing something here 9kw boiler in the airing cupboard? and shaun is sourcing a 22kw plate beware you have made one error double check before you do this . cheers kop
Reply to the thread, titled "Gravity to sealed question" which is posted in UK Plumbers Forums on Plumbers Forums.
GQuigley67,
ShaunCorbs,
