Hi All,
My old Grundfoss pump failed some months ago, so I got the direct replacement UPS2 pump and installed it. Everything was fine for a couple of months then the pump went into what I assumed was 'smart' mode,running for 10/15 secs then stopping/starting causing the boiler to go into overheat, as we were going away I didnt have time to investigate so just turned the system off. When we returned the pump had sprung a leak so I got a replacement under warranty, Fitted it,refilled the system (one of my valves had failed) ran up both heating and hot water all was good so turned off the heating leaving the hot water on timed everything fine for a few days then the same problem it has gone into the proportional pressure mode and the boiler goes into overheat.
I checked the output to the pump and when the programmer switches there is constant voltage to the pump, (htg only/HW only/both) and the boiler fires up with no problems. I cant believe I have had two dodgy pumps so............ any suggestions/advice would be well recieved.
Thanks for reading.
Thanks for reading.
