Hairline crack
View the thread, titled "Hairline crack" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
darrenangel
I have a hairline crack in the corner of my shower tray. Is there a spray on, or paint on liquid silicone on the market. Normal silicone is too thick to penetrate the crack. Thanks in advance. Darren
Dont bother wasting your money,
MY OWN shower trays have cracked 3 times (3 plastic cheap trays) 1 even 2yrs, they developed a hairline crack which allowed water to pass through
I bought a china enamel tray ( held on a thick wooden base for plenty of support ) its been strong now for the past 4 years
Its like a exhaust of your car, if it gets a crack you can use exhaust putty, it holds for few days then the crack reappears.
Advice and best solution - BUY A NEW TRAY
Good luck mate 🙂
Any shower tray that's not sufficiently supported will crack over time. I always use 18mm plywood under mine plus sand and cement if it's a stone cast tray.
Reply to the thread, titled "Hairline crack" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
darrenangel,
Irish,
