M
mgm056
I was having problems with a torbeck float valve. Basically, the cistern would fill and the float valve would kick in. After about a minute though the valve would open slightly, water would trickle in and the cistern would fill to the overflow point i.e the valve would never completely close again. After reading a few posts on torbeck valves, I replaced it with a Fluidmaster PRO75B. So now the cistern fills, the valve closes but after about thirty seconds there is a short burst of water, the valve closes and this repeats every 30 seconds or so.......I have high mains pressure (about 8 bar from recollection) so there is a valve on the main supply into the house limiting the supply to 3 bar. The instructions only tell you to remove the flow restrictor in the PRO75B if the cistern takes more than 4 minutes to fill, but it fills in less than 2 so I have left it in place.
