Bit of a long story but here goes. I was called up a couple months ago to do a powerflush on a system as a year old baxi platinum 28he had been taken off of warranty due to a dirty system which caused a blocked plate heat exchanger. The guy that fitted the boiler refused to flush it, even though he should have done at the time of fitting. Heateam replaced the plate and took it off warranty. I then powerflushed the system, which wasnt overly dirt to be honest, and added a TF1 on the return just before the boiler. I ran it all hot, all working perfectly. No cold spots on the rads, all heating up better than before. I had to write a letter to Baxi confirming the system had been cleaned so they would take it back on warranty for the remaining 4 years. Job done.
Or so I thought. Got a call on Monday from the customer saying the boiler has stopped working and heateam have been out and said the plate heat exchanger and main heat exchanger are blocked and they arent fixing it. The guy ordered the parts for the customer for free but they wouldnt fit them. I spoke to the heat team engineer who wouldnt say how he came to the conclusion that they were blocked and he didnt really explore any other options, I'm guessing he just looked at the notes on the system. The customer said all the heateam engineer did was ask him to run a hot tap while the engineer looked at the boiler and then said both were blocked. I then have a customer saying the system was not flushed properly, so I said I would fit the parts for free thinking it was my fault.
I went there yesterday and replaced the heat exchanger and the plate and still getting the same issue, boiler locking out on the overheat, just taking a couple seconds longer to lock out. No real sign of any dirty water or likely blockages that I could see on the old ones. I then notice the heateam guy had booked up a pump aswell, so I fit the pump and it all works fine. Took the head off the old pump and no sign of any sludge or dirt again??? I inform the customer all is fixed and the pump was the problem and there was no blockage. I drained and refilled the system a couple times to make 100% sure there is no debris floating around, although the TF1 should catch it anyway, add inhibitor and away I go.
I then get a call this morning to say this morning the hot water is playing up going hot then cold??? I have told them to get in contact with Baxi as they should have fixed the last problem. I dont see why I should lose any more of my time over a boiler I didnt even install in the first place.
Rant over. Heateam arent in my good books. I will say the boiler was nice and easy to work on, very quick to change all the parts I had to.
