Agreed the valve isn’t the issue. But it shouldn’t be there from a safety perspective. Agreed check the pump is turning. If it is, is it weak? If it’s not turning is it getting power at the correct time?Quality, the valve isn’t the issue, first off you can only guess and question what previous issues there was and what plumber done, depending on size of system I have actually plugged cold feed from tank fitted ballofix to outlet and flexi pipe to cold mains feed allowing mains pressure to fill system, the reason for ballofix was to isolate, remove hose from mains and allow any overpressue to feed back into tank before removing ballofix and connection back to tank before removing plug,
First questions are, is there still power to pump, is the pump running on demand and have you checked when there is a demand the power is at pump
