F
fixmeuk
Can anyone help please? I have been asked to look at why the rads don't heat up by a client and I think it's the pump thats the problem.
The boiler fires up ok the water gets hot but the heating does not.
The Boiler is a Sime Superior 50
it has 2 motorised zone valves, Pump and timer It's all quite old except for the motorised valves which I am told were recently replaced (in the last 2 years or so) the pump also looks to have been recently replaced.
The Boiler fires ok, the water in the tank is hot, the vaves move when switched on an off but the pump does not run.
The wiring althought a bit heath robinson appears ok (no loose wires in the block) I think the pump is faulty is there an easy way I can confirm this before replaceing it?
