scanny1
Just fitted a heatline monza 24 kw cheap and chearful.Did the gas rate the lower temp gas rate was 31ft3/hr which was bang on .But at full heat i was getting 83ft3/hr which seems high as The gas rate table shown in the instructions states i should be getting 68.4ft3/hr.
Then i looked into the technical data but that shows DHW gas rate full heat 87.7ft3/hr which then would be ok within tolerance .Never had this before installing them
