HELP! Experienced engineers advice needed please! Baxi Combi 80 hot water problems
View the thread, titled "HELP! Experienced engineers advice needed please! Baxi Combi 80 hot water problems" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
Luke Warm
Hey guys,
I'm having quite a stressful situation where i work for a company of gas engineers, we get sent to all types of jobs and sometimes we end up back at the same job, in the meantime a different engineer may have been there and also completed work or parts may have been requested by one engineer and not fitted by the person sent to fit it because they find or think the part is not needed. so you can imagine how hard it is to diagnose things sometimes. but anyway..
I have a baxi combi 80, i am either getting teppid water from the hot tap or if you try to reduce the flow (as you would normally do to see if it gets hot if the flow is reduced) the boiler wont even fire.
when the hot tap is on fully, you get barely warm water from the hot outlet BUT, the bottom of the divertor valve is red hot! and so is the flow pipe, so i was sent to change the divertor valve. and we are still getting the same problem!
when i was previously at the property i requested that the plated heat exchanger was replaced, but i think the engineer that was sent to replace it said it wasn't needed. and therefore did not replace it.
i rang baxi and they said it was either the plated heat exchanger or something like the inlet venturi assembly? apologies i cant remember the actual name of it but it basically has everything connected to it and it hhouses the pump body!
hopefully the information i have provided is sufficient! please help before i have a nervous brake down! :bucktooth:
Re: HELP! Experienced engineers advice needed please! Baxi Combi 80 hot water problem
i guess i need to put my gs number in somewhere?
read the link i posted but here it is
"If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum."
Get that post count up. It's easy once you get going!
I really must get round to changing that!
OP. Send pictures of the front and back of your gsr card to uv.ukpf@gmail.com once you've hit 10 posts please.
Reply to the thread, titled "HELP! Experienced engineers advice needed please! Baxi Combi 80 hot water problems" which is posted in Gaining Plumbing Experience on Plumbers Forums.
Luke Warm,
Dotty,
