I would pop down to your local screwfix or toolstation and get a cheap multimeter, as i said it doesn't need to be expensive, you'd probably get one for around £15-£20.
From there I would be looking for 230 volts between a neutral and the white wire on the actuator head. What that tells you will allow you to go from there.
Does it need batteries in the thermostat? Have you checked the batteries, and are they alkaline?
Yes, they're Energizer alkalines, replaced not that long ago. I think the thermostat is working fine - I can hear it click on (and the flame symbol appears) when I notch up the set temperature, and as mentioned, the actuator motor responds with this slight buzzing, and then stops when the thermostat clicks off again. As per @SJB060685, sounds like some electrical diagnosis required on the actuator head.
Reactions: Aquarius
