north facing wall and a 7m external run. so i put it up to 40mm too with a pair of 45's at the bottom.Why fit the condensesure thingy?
Ted : i wanted to try to keep the flow from the syphon up as much as i could 🙂 i have no idea if it will aid it or not but here's hoping 🙂
as i was soldering up the expansion vessel i realised i dropped a bollock with the inline magnetic filter on the cold, if it had leaked i woulda had to fein it out and use slip couplings !!!
thanks tamz, appreciated 🙂
I'm not entirely sure why you've bunched all your pipes together in the centre like that?
Neat enough job, its just confusing to look at.
I try and work to the rule of keeping the pipes straight from boiler valves or outlets for as long as possible. So for example, even if you had a mish mash of cross overs at skirting level, if from that point if they run up the wall straight into the relevant connections, your eye is drawn to this and it makes the job look neat and tidy.
Like this? 😉
Reply to the thread, titled "help me grow" which is posted in UK Plumbers Forums on Plumbers Forums.
