We were told MI exceed anything else....but I'm 99.9% sure it was across the board as a general to do with high/low level vent. That was my understanding of what we were told.
With room sealed boilers, vents serve only to dissipate heat as not required for combustion. The mi's for the boiler shown dont require them wich makes sense as most modern room sealed boilers are in essence appliances within there own compartment (casing) which is ventilated by the fan drawing fresh air through the concentric flue in to the inner boiler casing.
my gas, flow and return come into that run of the joists but my hot and cold came from the left, i didnt want to cross them over high so i chose to do it low 🙂 i'm sat here looking at it now thinking of how it would look good with all your snippits of advice !!!!!!
next time, you do better next time 😉
It says;
Note
It is no longer permissible to utilize a non-thermostatic controlled radiator as a by-pass.
So I fitted one.
Without trying to hijack this thread king, heres one I did today with cross overs at the bottom. The gas came out the floor in a silly spot but it was an LPG park home so wasnt going to mess around with it underneath.
Sorry about the Worcester, was a sub contract job.
It looked a bit better in the flesh I thought, looks a bit busy in the photo but you get the idea, sort the pipes out ASAP then continue up the wall straight.
Reactions: 2 people
Notice all toss bonded excluding the gas? I hate a tidy job. Much better to have pipes all over under boiler IMHO, make u feel less self aware!
Did you get any of the sets wrong? Or first time for every one?
Tbh my jobs are neat to a limit, no one pays extra for perfection.
Yeah, I think its because the meters are off a communal bulk tank externally and pme earthing arrangement so different potentials possible per park home.
leo, believe it or not I didn't mess up one bend! A few needed making a touch bigger but that was easy enough. Normally I mess one up but as it was my tube I took my time!
I don't do it for the customer mate, use to fit exactly the same for warmfront and will do for eco etc, if I'm happy with the job then 99 times out of 100 so is the customer anyway. I do it so that I can walk away knowing I've no come backs, and your work is your business card.
Thats fair enough, I do a neat job but don't go over the top. I'm not sure it's apreciated.
Sink hole? Residential park home, different to motor home ( as far as I'm aware!)
RPH requires a sink hole of no less than 25mm 🙂
unless low lever ventilation is at floor lever
rph's made after 2005 require a minimum of 25mm
made before that you have to provide it aswell but they don't give you a minimum size however i had a chat with an inspector over it and he said if you install a new applience make the sink hole 25mm to cover yourself 🙂
oh refrigerators needed a purpose provided 13mm minimum size.
Where can this be found king?
Covering yourself and a requirement are 2 different things, interested to know if I am mistaken though.
