help me grow
View the thread, titled "help me grow" which is posted in UK Plumbers Forums on UK Plumbers Forums.
just out of curiosity, why the extra expansion vessel?
Over engineering 🙂 as with the 40mm condensate run!!!
next time it will be better. Starting to build some confidence up now 🙂
looks good nostrum !!!
But wheres the sink hole for the lpg?
Notice all toss bonded excluding the gas? I hate a tidy job. Much better to have pipes all over under boiler IMHO, make u feel less self aware!
Yeah, I think its because the meters are off a communal bulk tank externally and pme earthing arrangement so different potentials possible per park home.
leo, believe it or not I didn't mess up one bend! A few needed making a touch bigger but that was easy enough. Normally I mess one up but as it was my tube I took my time!
Tbh my jobs are neat to a limit, no one pays extra for perfection.
I don't do it for the customer mate, use to fit exactly the same for warmfront and will do for eco etc, if I'm happy with the job then 99 times out of 100 so is the customer anyway. I do it so that I can walk away knowing I've no come backs, and your work is your business card.
image.jpgOne of mine, full system.
Thats fair enough, I do a neat job but don't go over the top. I'm not sure it's apreciated.
Sink hole? Residential park home, different to motor home ( as far as I'm aware!)
RPH requires a sink hole of no less than 25mm 🙂
unless low lever ventilation is at floor lever
rph's made after 2005 require a minimum of 25mm
made before that you have to provide it aswell but they don't give you a minimum size however i had a chat with an inspector over it and he said if you install a new applience make the sink hole 25mm to cover yourself 🙂
oh refrigerators needed a purpose provided 13mm minimum size.
Where can this be found king?
Covering yourself and a requirement are 2 different things, interested to know if I am mistaken though.
In my NICEIC lpg safety on site guide.
the bs numbers are bs5482-2 is for pre 2005
post 2005 is bs5482-2 and bs5482-1
I'll have a dig about. Never mentioned in the course or the re assess, never ever seen one fitted either but wouldn't be surprised if it is in there somewhere.
I'm quite lucky, when i do any training now i go one to one with the guy who did my apprentiship for it. Even did a saturday at his house. It means than i'm not learning with 10 other guys in a classroom and nodding if i half under stand it 🙂
Really get to learn and retain it that way.
oh yeah, looked like the condensate going down was in 32/40mm and the pressure relief was going into that!! funny how you can see different things in photos
Reply to the thread, titled "help me grow" which is posted in UK Plumbers Forums on Plumbers Forums.
Killy Bing,
Leo21,
