M
Magsk
[h=1]Hi everyone...I need your help...[/h] I recently bought and fitted a triton pietra electric shower to replace my 7 year old mira shower. When I switch it on it works perfectly, great pressure and temperature, after about 2 minutes I hear a 'click' from the shower and the pressure drops, the temperature remains the same but the water pressure is poor but the 'low pressure' light does not come on, switch it off and back on again and the shower works fine for again around 2 minutes. Help!!?!?
yep stopped using triton shower 20 years ago fed up with being rubish out the box .
if its got a warranty and your sure you have fitted it correctly then just ring them and get them to fix it
but make sure its all correct first as they will charge you big money if any deviation from instructions are found .
maybe try checking there are no debri's in the water ie: jointing compound soldier etc wich can move about when water is flowing . good luck
