View the thread, titled "Help needed please as outside tap doesn't work" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
L
littlewren
I used my outside tap last summer and when I went to turn it on today, it wouldn't work. What happens is this - I turn on the t part of the tap but it just unscrews, it doesn't seem to grip anything, it's like using one of those taps in somewhere like Homebase where they're not connected to a water supply but are just there for show. There is a nut underneath the screw section (where the t part comes off) but when I loosen this with a spanner, that's all that happens, it just loosens.
I don't want to call a plumber out for what might be a simple solution, but I am a complete novice - in fact less than a noive - when it comes to anything like this, but I was wondering if anyone could tell me in simple terms what I could do to solve it please?
Many thanks in advance,
Carrie
i would check inside to see if the water is switched off (which is should have been to prevent freezing during the winter) at a valve on the internal pipework try to follow the pipe where it comes through the wall from outside
Hi, thankyou for your reply.
There is nowhere inside that the water relating to the outside tap can be switched off apart from the stopcock, which of course is on, although it's stiffened up and can't be turned 🙁 There's nothing separate for the outside tap and never has been. I've had the tap for about 5 years and never had this problem before.
Carrie
is your tap like this one? if you are sure the supply is on to the tap the next thing is to check the washer in the tap as it might be jammed, you will need to isolate the main supply (use a spanner on the handle to get more levereage if it is stiff) then use a spanner to unscrew the tap assemby where it joins the tap body, there will be a place for a 2omm (approx) spanner to go on, hold onto the tap body where it is screwed to the wall or you will pull the whole thing off the wall, when you remove the tap head it will have a rubber washer on the end of it, or it will have come off and be stuck insed the tap body, remoe with a screwdriver and refit, screw tap head back in and turn on water and all should be well, OR GET A PLUMBER IN!!!!!!!!!!!!
When you say 'isolate the main supply' what do you mean? If on the tap, how do I do this?
I would get a plumber in but I can't afford it unless absolutely necessary. 🙁
Thanks very much, Carrie
you will need to turn off your main supply to the house(if you strip he tap and free the washer the water will be flooding everywhere!!!!!!!!)
If it is a tap with integral check valve, the valve could have been damaged by freezing during the winter.
Personally if i was you and that skint id turn the water off at the mains, go to the tap and slightly undo it from the back plate then turn water on, look to see if there is water coming from the tap from wer you loosened it, any water will gush on the floor but after all its outside! if there is water its obv the tap. So just buy a tap for a few quid and swap it. all you will need is ptfe tap and some water hawk or similar. Everyone was a novice at some point.
No, I can't turn off the water as I mentioned, as the stopcock is jammed, and I've tried to turn it but it won't budge. 🙁
and yes, it is like the tap you mention.
Thanks for your replies, but unfortunately I'm stuck because of the stopcock being jammed. I'm not that skint but I was trying to avoid calling out a plumber if possible because of the call out charge and then the labour & I AM having to watch my money.
Thanks anyway. 🙂
Would that mean that the top of the tap would just unscrew when I turn it, there's no actual tension that you usually feel when you turn it on or off?
If you can't turn the water off I'd see to this soon. If you get another problem (say a WC that starts leaking) or another tap that fails you'll have to turn the water off.
A new outside tap and some PTFE tape won't cost much as mentioned above.
you mentioned you loosened the nut on the tap "under the t bar" try this on your main stopcock, when you loosen the nut you should be able to turn your stopcock (REMEMBER TO TIGHTEN THE NUT WHEN YOU ARE DONE AS SOME WATER WILL PROB DRIP OUT OF IT)
Reply to the thread, titled "Help needed please as outside tap doesn't work" which is posted in Gaining Plumbing Experience on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
littlewren,
littlewren,
