Bet you mixed some paint with it 😀
Linseed oil added sometimes. Had to work the putty in my hands like a baker with dough, to get it workable.
Boss White paste was good to first apply onto the dry old floorboards to get the putty to stick.
Glad to not be using putty now.
The putty on pans fitted 50 plus years ago turns as hard as stone on the wood and you have to carefully chisel it off, as you probably have come across
  • Agree
Reactions: Ted808
My guess is Watertight has tried to ease the stupid thing off to get to into the cistern, cracked it and then for a micro second had that thought "maybe I can actually just do a runner?" but did the right thing and gone downstairs to be asked "how is it going?"...erm..
That's how it happened yes. One thin bead of silicone between back length and wall which had been thoroughly cut with stanley. Easing it off and cracked. As somone else said previously it was likely pretty weak in design. I won't be making the same mistake again. Problem is there are always some lovely fresh new mistakes out there just waiting to be discovered.
Combination Vanity Units
I've just fitted (and broke) one of these
BTW pan floor fixings snapped, so had to replace with a quality pair (Fischer) and when putting the pan back in I clipped the corner of the basin part with the pan (after hearing the almighty clunk, I closed my eyes and pretended I didn't hear anything and hoped I'd imagined it)
Lucky really, it only cost £260 plus 30 delivery and could have been a lot worse
The BTW pan fixings were of poor quality (and were left to get to room temp before using) and just shattered when trying to tighten into
Better bathrooms not interested in giving any sort of discount, my fault entirely but if fixings were of better quality the pan would have only gone in once
  • Friendly
Reactions: Phil
What snapped? the stupid L brackets with loads of holes in Jonny?
how high were you swinging the toilet around to chip basin?
Yes mate, the nylon "L" brackets, really brittle and poor quality
I picked the pan up to empty into the bath (it had been flushed/tested, but not used) and caught the corner
Aaaaaargh
I came across something like this!! Thought it was cement- it could've been- had to smash pan and then hammer and chisel to get floor smooth. Got a nice fix with new pan.
Reactions: Best
