really you just silicon the outside and hope for the best it doesnt move?
As Ron (Matchless) said, I meant I do use pan screws/brackets fixings if possible, but a bead of clear silicone will stop any movement in pan. Also it will fill in any irregularities the tiles or pan have, so making sure pan has full contact with floor.
I have fitted some of the large base modern pans, solely relying on silicone to hold them in place. But they definitely will never move on tiles if pan remains untouched until silicone cures.
I no longer bed the pans on a pile of silicone. It is too strong and wasteful and not easy to do.
A bead put around the already installed pan and then tooled off is plenty as the base of pans always has a stepped edge.
That way you can remove the pan hopefully in the future using a flat blade .
