I've just moved house and need some help to sort-out my plumbing. The previous owner used a well-known domestic maintenance services company and they have left me with an unserviceable hot water system. They have fitted a shower pump with 15mm tails (installed via a Wessex Flange) to boost the water pressure in the hot and cold systems. However, if the hot water is turned on and the pump starts, the pump will not turn off again until the electricity supply to it is turned off again. From the photo below, it's fairly clear how the plumbing was originally connected. I am guessing that this was originally a recirculating system. However, the circulation pump (2nd photo) is on a 15mm feed from the side of the cylinder. How/where will this connect to the two hot feeds (one in 28mm, the other - with gate valve - in 22mm) ?
The isolating gate valves on the circulation pump appear to be shut off, but I believe they are seized part open. With the shower pump off and a hot tap opened, the outlet of the circulating pump and the 28mm feed both get hot. If the shower pump is then turned on, the outlet of the circulating pump gets cold and the 22mm feed (with gate valve) also gets hot. Where is this cold water at the circulating pump coming from? Also, there are gurgling sound with the shower pump on. Is air being sucked down the overflow?
Is my best bet to return the layout to the original configuration and restore the circulation pump? If I need to increase the water pressure for the top floor shower, say, without installing a separate feed (so negating the advantage of the circulating system) I could install a pump locally. Would I need to keep the Wessex Flange for this as it will restrict the total hot water system flow?
Is anyone able to provide any insight and advice?
