Hep2o pipe inserts?
View the thread, titled "Hep2o pipe inserts?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
At 18 bar you should have an isolation zone of the whole house, even plastic firing at you at 18 bar will cause serious damage..
That's why you loop all ends and never put blanks on if a fitting comes apart it'll still be connectedto the other pipe, like I said hepworth came out and trained us
Hope ur wet testing and vent all the air off. Compressed air at 18bar makes a lovely jam from you skin and connective tissues.
Air testing o longer allowed due to health & safety etc
but yes, I still air test... Half or 1 bar just to check no open ends etc...
On site work 1st fixing, a bit of spilt water doesn't matter so no need to worry about any forgotten open ends apart from air testing being dangerous it would also be useless cos if you had a small leak you would struggle to find it,
Thought i was rite about that, i remember at the time being a bit scepticle about pumping to 18 bar. Air will release 7 times quicker than water i seem to remember so i wouldnt use air over 1/2 bar to test. As for 18 bar its not that hard with a rothenburger its the filling before thats the worst from 3 up to 18 bar would literally be one or two at the most pumps on a house size system id say.
3 to 18 bar one or two pumps, more like 200 and two more buckets of water.
Got to 18 bar on hep couple weeks ago and after 5 mins a 10mm pipe split!
Week before another trade person accidentally trod on a pipe at 18 bar and it sheared at the fitting. Must have jumped out of his skin lol
HI GUYS ITS HURDY:sorcerer: AS A CONSTANT USER OF HEP AND BARRIER I WOULD NOT FEEL SAFE NOT USING INSERTS,IT WOULD KEEP ME AWAKE AT NIGHT KNOWING I HAD NOT INSTALED THEM,SO I FEEL IT IS A MUST.REMEMBER THE PLUMBING GODS ARE WATCHING.HA HA SEE YUO SOON:wazzzup:
I never used to bother and have never had a pipe blow off. But nowadays I'm less of a cheapskate so always use them, just in case :28:
Reply to the thread, titled "Hep2o pipe inserts?" which is posted in UK Plumbers Forums on Plumbers Forums.
Cainan,
Best,
